I live in Phoenix, Arizona, and just took over my pool for the first time. A few weeks ago my testing at Leslie‘s showed a CYA of 180. Did a partial drain that resulted in a revised CYA of 120. Did another partial drain, and subsequently learned about TFP. I purchased the TF pro test kit today and here are my results:
CYA 75, FC 4, CC 0.5, CH 700, pH 8, TA 130
Obviously, I can add chlorine and baking soda to adjust the FC and TA levels, respectively, but it also looks based on my high CYA and CH levels that I need to do another partial drain. Does that seem right? Ugh I really hope not. If I do, should I even bother with the chlorine and baking soda today or should I just start with the partial drain??
If I do need to drain, can I drain and then refill or do I need to instead fill at the same time as draining to keep the water levels up? this time of year the temperatures are low of 60 and high of 90. I have a pebble tech (plaster) pool that Leslie’s (I know I know the devil) says is OK to drain even when it’s hot, but it’s 20 years old so I’m very nervous about damaging it. Hence the partial I have done in the last few weeks. The last two times I’ve done it, I have drained a little more than half of the pool overnight taking about 14 hours and then refilled it with two hoses, taking about seven hours. It’s starting to get a bit warm out, though, so wondering if I should, drain from the deep end and refill from the shallow end?? Any advice would be very appreciated!
