- Apr 21, 2020
- 1,244
- Fiberglass
- Pentair iChlor 30
I have a couple of concerns about my equipment. At the pump at full speed, the pressure reads 19.5 psi on the sand filter. I don't know if that is high or not for clean conditions. When I run on recirculate, the pressure is 16 psi so the pressure drop across the sand is only 3.5 psi. I deep cleaned the sand. It didn't feel gunked up. As for the VSP, the SWG shuts off at 1670 rpm which seems high to me. I could run down to 1100 on my last pool. By running at least 1800 rpm under regular operating conditions, I don't feel I'm getting the full benefit of lower electricity usage.
Putting a FlowVis valve on the system, I measured around 46 gpm at full speed on the pump and around 10 gpm at 1720 when the SWG shut off. The FlowVis changed the minimum rpm speed for the SWG to run by 50 rpm higher. I don't know the accuracy of a FlowVis. The manual for the SWG says the flow rate should be 25 gpm or higher.
I was thinking of upgrading the pump to 3 HP. If I get the Pentair IntelliFlo, I would get 8 programmable settings. I assume the larger pump will allow me to run the pump at a lower rpm setting for the same flow rate as the current pump which will lower operating costs. Maybe it would even prime faster. Right now the current pump needs about 4:45 out of the 5 minute priming cycle to be pumping full flow.
I'm still debating if I should switch from a sand filter to cartridge filter for finer filtering. I'll probably hold onto the SWG cell and upgrade to a larger cell when it poops out. Overall, my system is pretty simple as shown below.
