- May 16, 2011
- 1,182
- Plaster
- Pentair Intellichlor IC-60
How precise are you being with filling up your test tube? I would hold it to eye level and when you fill to the line make sure that the bottom of the curve in the water lines up with the line. You probably already know this but I am really anal with this stuff and I don't know if it makes that big of a difference or not.
Make sure when you add the drops from your reagent that you do it slow so a full drop can form each time. I wait a second between drops.
Also do you have newer chemicals or are they from when you started your pool? I found mine were weak when I started using a new bottle of reagent for my chlorine test and the FC level was probably 20-30% lower with the new bottle.
If you already do all this you can tell me to shove offOh and I hated college chemistry because I would always accidentally do an extra drop from my pipette. At least with the pool it isn't as big of a deal.
Oh and one more thing is I always try to measure when there is no more sun out and I know my kids have been out of the pool for at least a hour or two. I think the chlorine can drop after dark battling whatever they put in there. Plus yesterday I had a ton of leaves and grass put into the water by my lawn guys and that was frustrating. My wife measured at 1 and mine had dropped to 15ppm and it was from all that stuff floating around. Thankfully she got it out.
Thanks ummm! I do appreciate your input. Yes, I am very careful about all the test methods you mentioned, but the one point you make that has me thinking is the reagent. When I started this SLAM I had the TFT stuff, but ordered a pint from Amazon because I go through it so quickly and didn't want to worry about running out. That date shows it good through summer of 2017 but it was mailed here through the heat of summer and sat in my mailbox the day it arrived. So it's probably giving me inaccurate readings like happened to you. Come to think of it, I think my beginning to use it coincides with when my SLAM started to get worse.
I wonder what I can do about it while I order some new reagents from TFT and wait for it to come? Does anyone know how to test its potency so I can just adjust my calculations and continue using it for now?
