- Jun 24, 2021
- 7,766
- Vinyl
- CircuPool RJ-60
Yikes! Sounds like you are covered. It is also going to be easier slam because you don't have to continually add product to the pool, you have automation.
You will want to adjust your feed rate to maintain FC of 12 (assuming CYA 30). You will want to watch it carefully, and do your FC testing every 2 hours or so. SLAM level is safe for pool and people. You don't want to raise FC significantly above SLAM level. If you are not careful, the Pulsar can spike your FC with an available 189lbs per day! At max rate, you can raise FC by 11 in 2 hours. It can get out of control quickly. If you can't be there to test, return it to your normal rate. Do not walk away from this pool with elevated feed rate.
Your FC consumption will be variable, and you will be constantly adjusting the feed rate up or down to keep FC close to 12. It will likely consume more early and less later.
You will also want to turn Pulsar off overnight. You would be doing OCLTs at night to measure progress. Make sure that your OCLT tests are AFTER sunset, and BEFORE sunrise. Link-->Overnight Chlorine Loss Test
