Picked up a new cheap gauge from Leslie's, and it reads about 20.5-21ish psi. If I turn on the 3/4" feed to the slide, it drops to a solid 20 psi, if not a hair under.
I am definitely getting better flow since removing the chlorinator. I am going to look into a Liquidator, since it has pretty high marks and is inexpensive.
I have no idea what the piping looks like underground. I would think that if there was a breakage or collapse, I would not be seeing nearly the flow out of the returns that I am. I guess we can only assume a very poor design.
So, I guess one option would be to get a pool company to come out and check it out. I am not sure what they can do besides dig up what they can, which is VERY unappealing to me at the moment. I am sure it would be a venture in the thousands of dollars.
The other option would be to live with it. What honest consequences are there to running my setup at 20psi in the long term? If it means a blown motor every few years, I can live with that. If I decide to go with a VS motor, can my piping handle a slightly higher flow rate to simply clear an algae bloom? I would obviously run the pump at a much slower rate during most of the season, which i would think would mostly negate the high pressure.
