Pool very green - chlorine not dropping overnight
baudilus
156
Toms River, NJ
Hi All:
I very rarely post because I've never had a problem I couldn't figure out based on the amazing help here, but on this one I'm a bit baffled (or maybe I just need some encouragement to continue forging ahead). Went on vacation for a few weeks, and had a pool company come and service the pool while we were away; by the time they came for the first service, the pool was already very green, and they couldn't get a handle on it. (Not knocking the company, I think it went too long with no chlorine before the first came). Anyway, I've had a green pool before, and always resolved it with chlorine, brushing, and time using the SLAM process, which usually takes 1-2 days to go from green to cloudy, then another few days for the filter to clear it out.
Anyway, the part that's confusing me is that the chlorine is not dropping much overnight, but the pool remains very green (unable to see the bottom). I've attached a picture of the stairs, and here are the numbers (tested myself to confirm the numbers from the pool store) from this morning:
FC: 11 (started at 13 after sundown)
CC: 0
CYA: ~30
TA: 70
PH: currently testing at 8.0, but before I started slamming the PH was at 7.5
I tested phosphates too, they're around 400, but this isn't my issue.
The sand filter has very old sand, so that would affect how fast it's filtering, but even if I had the filter only on recirculate, wouldn't that just give me a super cloudy pool full of dead algae? I did add some DE and the pressure went from the base 23 to 31 within a few hours. I just booked an appointment to replace the sand tomorrow.
I have a feeling the answer will be stay the course, which I will; I suppose I'm just more confused why the pool is staying green and the chlorine doesn't seem to be doing anything.
Hi All:
CC: 0
CYA: ~30
TA: 70
You lost 2ppm chlorine overnight so it’s time to SLAM. Get your FC up to 28ppm and hold it there until you meet the three exit criteria.
It's exponentially harder when it's warm out.
How often are you testing/adding ?
All sand is billions of years old. :) When was the last time it was deep cleaned ?
Reactions: Mdragger88
Testing every 2-3 hours. Keeping the FC at or around 12ppm. The sand was never deep cleaned; you think that's better than just replacing it?
And yeah, the water is unusually warm, so I figured that wasn't helping. And the rain here hasn't been helping either.
Why 28ppm? Based on my CYA should be 12ppm
Correct. To @Bperry 's credit, I misread the 70 TA as CYA also. I think we're pre programmed at that # because SWGs :ROFLMAO:
AWESOME. The more effort you put in, the quicker it goes, no matter how bad it might be.
Yes. You'll know as soon as you get in there. If it's still sand like, even if it's filthy and gross, it will clean as good as new. If it's gummed up and/or rubbery, you need new sand.
Thanks - will definitely check when they get here; I'm also going to have them add unions so I may just take the hit and replace the sand now, and then do the deep cleaning every year at opening. I could add the unions myself but I just don't have the time or inclination right now.
If you're going to do *anything* you don't necessarily need to, this usually doesn't break the bank. Sometimes the effort/ aggravation isn't worth the savings. (y)
Oops, yes would have sworn CYA was 70.
