Hi All,
Moved into this house in 2022 and inherited the pool and hot tub with all of their problems. Pool is losing 1-1/2 inches of water a day and one pool company employee mentioned that they did a pressure test and could not maintain pressure on suction side, but it was second hand to me and not in writing. Many of the pool companies in my area are terrible at customer service and very often are no shows for appointments, so I've been learning a lot from youtube and forums here (and have some prior experience from the onground pool and good pool companies at the last place I lived).
I've rigged up a pressure testing system and am about to start but I have two union related questions. I might not get an answer that I can work with on the pump question, but hoping that someone recognizes the union in the pic for the second question.
1. Does anyone know the male pipe thread size of fitting that I'd need to connect to the union that connects to my hayward super 2 pump? The plumbing is 1-1/2" and the pump union has RS750 written on it, but the size of the fitting to match that pipe thread is a bit of a mystery. Hoping that someone knows that size so I don't have to unscrew the union to measure.
2. (pic attached) - Suspecting a leak at or near the skimmer. Hose comes out from underground just past the pool deck, and under the patio deck, and then runs over ground (under deck) to pool room that is in the garage. I'm going to start digging first but was wondering what this union was - maybe a check valve? Sounds like it's sucking air (gurgling a little), but I dont think its the source of the leak, because the ground is not so soggy beneath it, and it seems I'm loosing a few hundred gallons a day (I think). Ignore the dark grey hose - its just a garden hose that's going to the hot tub (out of frame).
