So I didn’t open the pool this year but last year was my first year of home ownership. I have a fiberglass slide that had broken hoses and missing nozzles so I figured I’d be able to fix it by buying one of the pool slide spray kits
After setting it up, the pressure was terrible.
I’ve since had some landscaping done and they had to cut the black poly tube that went under the concrete and went to the slide.
My questions are:
Why was my pressure so terrible?
Is it because of the thin clear tubing doesn’t let it provide enough pressure?
Or is my 1 HP pump not strong enough?
Should I Re attach the black poly tubing into the pvc and if so how?
Or should I knock out the tubing that is under the cement and start from scratch while I can before I have dirt added to my yard.
Distance from pump to slide is approximately 20-25 feet
Pool size is 20x40
I’ve attached photos and indicated with red the path from filter to slide
My questions are:
Pool size is 20x40
