Also, it looks like your CYA has dropped to 40, probably from all the backwashes, so you only need to maintain an FC of 16 per the
FC/CYA Levels. My opinion, I wouldn't bother with the DE right now. Your water is much to green. We usually save DE for the final clarity stages "if needed". Curious, is your polyfill still catching iron?
As I noted earlier, this is a body of water with an unknown history and it was very green. It is the past history and unknown chemicals that concerns me most. I'd say that if you don't see notable improvement by Sunday morning, you might want to consider a healthy water exchange - about half. That should help to remove residual products that may be hampering your progress, expedite the
SLAM Process, and perhaps save you chlorine over the long run. Something to think about. During that exchange period would also be a good time to open the filter to examine the sand. I don't think you changed it did you? If not, it may be gummed up from the previous owners or just need a thorough deep clean.
