Hello! First time pool owner that gets a lot information reading the TFP forums. First time posting as well.
We had some strong winds yesterday and I noticed once I got home, the pool skimmers baskets were clogged with leaves and other debris as the pumps were running on a timer. I could tell there the skimmer baskets experienced some pressure drop from the pump as one of the baskets had a tear/crack in one side.
I took time cleaning the skimmers and noticed for the first time the suction holes on both skimmers have what appears to be some sort of plastic separation (images below).
Should I be concerned if this is the start of a bigger issue?
I was thinking this maybe plastic/PVC remnants from the plumbing installation process, but was not entirely sure. The pool itself was built in around 2016.
Though both skimmers have two holes, I assume the other hole is not used on both as the holes only contains static debris... no plastic separation observed in these holes.
Thank you in advance!
