Hello all!
This morning I got up and my pool pump was off. It is on a timer that runs 12 hours a day. I hit the reset button several times but it immediately shuts off again. I did notice last night that the plastic cover that I use over the motor to help keep it cooler looked a bit rough… As in a bit burnt? Photo below. We did have storms last night but no other issues with any other part of the house. Second photo is the specifications for the motor on the pump. Installed May 14, 2021 when it was difficult to get parts and this is what the pool company had at the time. Should a pool pump motor last more than two years? It has not been all that hot here in southwest Ohio this summer…
So my questions are:
Should I assume that my motor is shot and get a new one pronto? If so, do you guys have a recommendation for what I should look for? It looks like it might not be too difficult to install myself… especially with your expert guidance . No new wiring or anything.
Or should I call my electrician first?
Thank you!
Thank you!
