- Apr 4, 2009
- 28
- Vinyl
- Hayward Aqua Rite Pro (T-15)
Hello all, been a while since I last posted...
I would like to know if anyone has an automated solution to shutoff a pool pump if a low/no water pressure situation arises (without paying for a commercial type system like Aquarite or Hayward!).
Background:
A few years ago, we were travelling and I've always been able to control my pool pump remotely with various means. Long story short, a pvc joint came loose on my roof (solar panels) and started pumping water out profusely and my neighbor, thank goodness, noticed the problem and ran over to shut off my pump and needless to say, saved us several hundred, if not thousands of, dollars in damage. - I'm sure you can imagine if the pool drained and cavitated the pump, etc!
Anyway, what I would like to do is have some sort of pressure sensing ability that can either alert me, or better yet, set off an automated pump-shutoff when a low or no water pressure occurs with the system . I'm proficient in Alexa, Home Assistant, Homekit, etc.., and was just wondering if anyone has a quasi-fail-safe solution setup for being away from their pool for extended periods. I have the Aquarite salt system and Hayward heater and pump, so just running the pump is sufficient for maintaining the pool for a few weeks.
My thought process is a simple inline pressure switch that indicates whether the contacts are open or closed, but I can't wrap my head around how to implement it or monitor it remotely. Just simply looking for different ideas on how to achieve this.
Thank you, everyone.
Background:
