Hi everybody, pool newbie here and need advice. My pool construction is nearly complete. Waiting on plaster, water, and start up. My hardscaping around the pool is done.
A few days ago my PB asked me to check the PSI pressure at my equipment pad, up to that point I was clueless about the pressure gauge, PSI and just assumed because the pool was incomplete, and I did not have to pay attention to it.
The PB asked me to check the PSI and said it should be between 10-20. I checked the pressure it was 0. Oh no.
The next day the PB came, added 20 PSI with an air generator and told me to monitor.
Exactly 24 hours later the PSI was at 13 and continues to slowly decrease.
The PB said he’s not concerned and said if there was a leak in the pipes, we would know within minutes of adding the air. He said slowly losing PSI makes sense because none of the seals are fully tightened on the equipment or skimmer area and the air is likely getting out there and all that work will be done at the time we fill it up and get the equipment going.
This is all so new to me and I am getting paranoid and I don’t know where to turn for advice.
My fear is there is a real underlying issue, we make final payments to the PB, and a few weeks out I’m screwed and get stuck with dealing with the issue, having to breakup the paver landscaping, dig to find leaks, etc.
Am I being overly paranoid?!
Please help!
Thank you so much in advance!
Please help!
