Hello,
I recently bought a house that has no drainage area at this section of the pool in the picture. The other side of pool has deck o drain but in this section of the deck there is no drain solution and it just puddles up there. Today it rained excessively and with no where water to go, all the dirt and debris went in to pool.
Does anyone have suggestions on improving drainage for this problem? The deepest area is where the deck column is.
The pool pump under the deck to left side marked with an red X and I believe a drainage pipe runs under the landscape trees marked in a blue line as I can see outlet of the pipe past the stucco wall.
