pool out of plumb
Theone01
13
Haverhill,ma
So our pool sank. the sides of the oval are out of plumb. Found out installer put in patio block under them.
since that happened the top inside rail has also stretched at the top in a few places
pics below
any advice????
What brand of pool do you have? Have you seen any the installation instructions?
Our Doughboy instructions require cinder blocks under the side uprights due to metal pressure pads under those uprights. The rest of the uprights use 12"x12"x2" patio blocks. Also the spot under the patio block must be dug out to the correct depth. The ground must be level and undisturbed under where those blocks are placed. They cannot be backfilled with dirt if dug too deep. If backfilled, they could settle.
Hope this helps.
:snorkle:
Hopefully your installer put the cinder blocks in the right way as they are only structural in one direction. Meaning they would have had to solid fill them or put something top and bottom
