Moved from here.
Can I piggy-back on this question... On opening (part 1) of my pool yesterday I also had a 0 CYA reading (fine in fall). I also had a 30 reading on TA so I added baking soda and brushed. Today someone is coming to actually start up the pump etc. My plan is to add acid to bring down the pH (blazing red so over 8.2) and then THEY will add chlorine (and algaecide because that's what they do). But should I try to do something about the CYA before they add chlorine. How high should I get it (in anticipation of a SLAM)? The problem is that the pump is not running yet. Next year, hopefully, we can open completely ourselves. But I still wonder how high you should get the CYA to in order to know how high to get the chlorine to when they are both close to 0 and you want to start a SLAM. Thanks so much.
