It seems like the folks who started helping me at the beginning of this thread haven't returned in a while, so let me update the timeline of everything I've done for my pool since opening it. Pool pump/filter has been running 24X7 since 5/12.
5/12 - Opened it. Green swampy conditions.
5/13 - Used 30000 gal/super start up kit version of in the swim pool opening kit: model Y6200
http://www.intheswim.com/Pool-Chemicals ... ine-Shock/
5/13 - Put in 2 quarts of the algaecide in the kit, put pump on recirculation for 24 hours
5/14 - Put in 4 lb of shock from kit, followed by 2 quarts of rust/stain scale preventer & clarifier a few hours later. Pool stayed green, with slight green color improvement
5/15 - Pool store test showed PH really high, over 8. Put in PH down (5 lbs?). PH returned to normal 7-8 range.
5/16 - Put in "Green to Clean":
http://www.intheswim.com/Pool-Chemicals ... To-Clean-/
5/16 - Put in 7 lbs of shock shortly after putting in Green to Clean. Green colored water turned to cloudy white/blue.
5/17 - vacuumed to waste most of the ****
5/18 - Water was not clearing white cloudy. Started to believe I had a filtration problem
5/18 - Replaced Sand in Sand filter (all 300lbs). Put in pool vacuum
5/19 - In the past usually can see improvement in clarity, did not see this, so I added DE to the Filter, about 12oz.
5/20 - Still no improvement in clarity, bought pool store clarifier & "sand helper". Put in 8oz of magic blue clarifier. Also added about 12oz of "Sand Helper" after backwash of DE out.
5/21 morning - Still no improvement - Losing patience so I put in a s-ton of DE. Not sure probably 24-36oz.
5/21 afternoon - Still no improvement - Pump pressure can't be determined, but based on flow and operation of spa jets in pool, seems like flow is not strong. Backwashed out DE. Put in 12 oz of sand helper.
5/22 - Still no improvement. decided to not do anything and give the pool time.
5/23 morning - Still no improvement. Decide to wait until I get home from work.
5/23 late night - reading about chlorine demand and break point chlorination. Don't have anything besides pool test strips. In a rage of futility I run to Lowes and buy more shock to put in, in addition to extra shock I have on hand. In total I put in 18lbs of shock. Here are the kinds I put in:
4 lbs of standard in the swim shock:
http://www.intheswim.com/Pool-Chemicals ... ool-Shock/
4 lbs of Lowes "shock plus":
http://www.lowes.com/pd_34629-1772-2210 ... facetInfo=
10 lbs of Lowes "Shock X-tra blue":
http://www.lowes.com/pd_254293-1772-228 ... facetInfo=
5/24 - I start this thread due to being defeated. Forum members describe my pool test results as not reliable however, if they are reliable they suggest I drain half the pool and refill.
5/24 - I order my Test Kit from TroubleFree Pool.
5/24 - I drain 1/2 my 30000 gal pool.
5/24 - I begin refilling. Put in one gal of bleach
5/25 - Still refilling. Put in one gal of bleach
5/26 - Still refilling. Put in one gal of bleach
5/27 - Refill completed. Put in one gal of bleach. Finally I see improvement, which is no doubt due to half the water being replaced. I can see the bottom of my pool but its still fuzzy.
5/28 - No improvement since refill. Still waiting for test kit. Decide to go to pool store to get updated "pool store" numbers. Pool store numbers are:
Pool Testing Device: Waterlink DataMate 10
Free Chlorine: OVR 18.02 ppm (appears to be above the highest reading possible for the test device)
Total Chlorine: OVR 18.02 ppm (appears to be above the highest reading possible for the test device)
Combined Chlorine: 0 ppm
pH: 7.2
Hardness: 187 ppm
Alkalinity: 67 ppm
Cyanuric Acid: 64 ppm
Copper: .1 ppm
Iron: .1 ppm
5/29 - No improvement since refill. Still waiting for test kit. Hopefully it arrives today.
