I am having extra trouble this year with all sorts of algae due to the Texas heat. Our pool is about 36,000 gallons (we think) and is about 20 feet from our lake. This means we end up with all sorts of critters in our water daily: frogs, snakes, turtles, mice, you name it.
We have a tower for chlorine tabs set to it's highest setting, and the Intellichem system set for pH and ORP. Despite both, and adding tabs to our baskets occasionally, and shocking, and adding algaecide, our chlorine levels remain on the low side and we are fighting all sorts of algae constantly.
Our Cyanuric acid level is good so I don't think it is that. No one in our area deals with the Intellichem system, so I'm having to learn as I go. We've had the system for about 8 years, and done "okay", but this year has been absolutely terrible. My thought is to increase both the settings for the ORP (to around 800) and pH (to around 7.5) to see if I can have more free chlorine and hopefully less algae, but before I do that I thought Id ask if anyone else has dealt with this sort of issue.
Having a constant source of algae introduced into the pool from all the animals makes things way more challenging than normal. This is not my first pool, but my first with this system. Thank you in advance for any help you can give!!!
