Hi,
Just wondering what the different goal levels are between TroubleFreePool.com and Traditional Pool setup?
Also, I have just taken my latest pool readings and am not sure what I should be trying to adjust first. I should also mention that I could not complete a couple of tests as my testers are out of date and not giving reasonable levels anymore, either that or the pool is that far out of whack that I will be crying if the measurements are true?
Currently
CL = 0.0 I have an SWG and have only just got the salt levels back to where they should be so hopefully chlorine will now start to be produced again?
PH = 7.9
TA = 110ppm
Salt = 4600 ppm
CH = 2500+ Which I'm hoping is not accurate. I gave up at 100 drops of solution.
I should add that I have bought an el-cheapo test kit to use to compare with my out of date kit just so as I can see how true my old test kit is still, but unfortunately, the new kit lacks a couple of those extra tests that we all like to also test.
Cheers,
John
Currently
PH = 7.9
TA = 110ppm
Salt = 4600 ppm
Cheers,
John
