I have a pool/hot tub combination. It's all on the same filter system, but you can configure the valves to and from the pumps to connect to only the pool, only the hot tub, or both.
I pay a company to open and close my pool at the beginning and end of the season. They've maintained this pool since before I moved here. This year, when they came to open the pool, they did it completely incorrectly. They ended up setting it up so that it was pumping water only out of the hot tub through a floor drain and into the pool, which very quickly drained the hot tub and left two pumps running dry. They left the pump running all night (well over 12 hours), and I only caught the issue this morning.
When I caught it this morning, I obviously turned everything off. The main pool pump was boiling hot and when I opened it steam came pouring out.
I'm at a loss for what to do. I reconfigured the valves correctly and had it run long enough to refill the hot tub. It doesn't seem to be running as well as last year. It's slow to prime and doesn't seem to completely fill with water. I haven't checked the pumps for leaks and they're off now. The main pool pump was almost brand new.
The hot tub heater (gas) was also powered on, but I'm not sure if it was running. There's also now a strange leak in the intake to the heater that definitely wasn't there last year.
What can I tell them to do to make this right?
