- May 17, 2023
- 20
- Plaster
- Pentair Intellichlor IC-40
I have: 3 Globrite lights ~100 ft to J-Box, and a 300W Pentair transformer about 10ft from J-Box.
What wire should I run from from transformer to J-Box?
Can I use 8/2 Underground Feeder Cable UF-B Copper 600V? I've heard that voltage drop is a major issue with 12V, so I was thinking to use a large AWG, does it make sense?
The ground wire is not needed for 12V, but can I use the 8AWG ground wire inside UF cable as a bonding for the J-Box to Transformer, or does bonding MUST be outside of the box?
