I left my robot on last night (forgot to turn it off)it was spinning with one tread off a tire in the same spot. This morning I woke up to the water level right at the bottom of the pool skimmer level (on the inside wall of the pool). The water level hasn't dropped all day today so I dont suspect it is the liner, unless it is right at that water level spot. I am now filling it back up to see it it holds water without the filter and robot on. One thing I did notice on one of the pumps that is above ground is that it was leaking fairly decently. I am just not sure that would cause the pool to leak out 4-6" in a 12-14 hour period. Thoughts? I am wishfully hopping it is just that pump leak, with a bad gasket or seal.
