Alright, I got the pool up and running and I am getting to the water next. PH and CC are good for now. I had an issue last year, and my poolmiser would "band-aid" the issue.
So here is the problem, every night when the pool filter ends its cycle, over the 8 hours it is stopped, the water in the spa retreats to the level in the picture and stops. above the jets. it does not go any lower than this. In turn when the filter kicks on in the AM, water from the pool fills the spa and goes thru the spill ways. Also the level in the pool also drops just a little as seen in the picture and stops, goes no further, again above the jets. when this cycle repeats every day, eventually the water line gets lower and lower and in a number of days, drops below the skimmer. If I have the poolmiser on, it band-aids this and life goes on at the expense of a water bill.
I am starting to wonder if I have a bad seal in the multivalve, as I already changed out the one-way valves in the SPA and heater piping last year. Water is going somewhere and IF it was a piping leak, it would not just STOP at a certain level, but down to the pipe that is broken, so I am thinking it is something else.
Thoughts?
BTW. How does one get rid of the calcium deposits shown in the picture? from the previous owner who ran the pool 24/7
Thoughts?
