I have a Pentair HeatPump HP 1200. I purchased it used two years ago and all has been good. This season I opened the pool and once everything was in working order I tested the heatpump. It started up just fine and was heating the water. Pool has been open about a month now and when I went to power the heatpump on it will not start up. I disconnected it from the automation panel and no difference. The fan will not start up and the heatpump never starts up. I have no error codes. I tested the capacitor and it checked out as working. I do have some strange things going on with the control pad. When I press the on/off button it never turns the green light off that says heater on. The second issue is the up/down buttons to adjust the temp will bring up the software version so I cannot adjust the temp. Could it be the control pad has gone bad? Just looking for any advice.
