Ph-8
Ta-90
ch-60
Cya-60
Fc-30
cc-30
Taylor k2006 kit. Shocked and shocked and used
Green to clean n still green
Ta-90
ch-60
Cya-60
Fc-30
cc-30
Cloudy green
3ppm for both
Brushed the walls? Did you see stuff come off?
The Ph level is pretty high which can result in algae growth, plus clogging filters. Chlorine levels are definitely high enough to kill algae and then some though...
Did you run the filter for 24hrs and backwash? Not a sand filter expert, so this may be wrong, but did you add DE to make sure it's capturing everything? Check the sand condition as well?
How long have you been taking this on and what have you done (the more information the better.)
