Having problems when I add water (softened). I'm still getting some iron or minerals (or something) through the softener b/c my water turns slightly cloudy and there's a greenish tint to it. After letting it settle (usually over night) I vac it out to waste but eventually have to add more water to keep the level up so it's been a vicious cycle of fill, vav, fill, vac.....and the water is seldom clear like it should be
I'm having no issues with keeping my levels where they should be other than alkalinity because of the well water.
I haven't had my fill water tested yet for iron/minerals but probably should
FC - 4
PH 7.4
TA - 200
CYA - 30
CH 120
I've looked at other posts about filtering the water from the hose (some for/some against) and am to the point where I'm willing to try about anything as a fix. The stuff sweeps right out but it usually takes 2 times to get it all but then needs more water of course
Attached are some pics of the stuff on the side of the stairs after sweeping (the pool bottom is usually twice as much) and one of the pool after sweeping to waste (cloudy -ish). This will settle out and will have to sweep it again to clear it up
Looking for advice on what to do
/R
FC - 4
PH 7.4
TA - 200
CYA - 30
CH 120
/R
