Hello everyone, I am noticing significant cracking in the concrete slab that my pool equipment rests on.. It was only a slight crack a few months ago but with our monsoon rains it has now gotten worse. So a few questions. It sounds like an expensive proposition to have someone remove all the equipment and then have another company pour a new slab, then replace all the equipment.... Has anyone had to do this? Also is it necessary that the equipment rest on a concrete slab. The Jandy pump appears to be drilled into the slab. However the Pentair filter is not secured to concrete. Could I replace the concrete slab with brick pavers or other solid surface vs concrete? Thanks Gina
