I do not know why you would want to be pumping water to the floor and NOT filtering it. That just seems wasteful to me and maybe why your gears and pop ups are not working.
I always ran the floor system. That is what they are meant for. They need to run a lot to be effective and with a big pump so use a lot of power. Thus I would not do it again. Robots are cheaper and more effective.
I could have changed the valve to return to the wall, but there was no reason too. It was really a backup if there was a problem with the floor.
One of the floor zones was in the spa and would spill over the pool. If I wanted to use the spa, I turned 2 valves and flipped on the heater.
Waterfall was small so did not use too much of the floor flow, but it was plumbed on the pool return side so could not be used while in spa mode. This was a decision I made when building the pool.
