Hi guys
Ive had a bestway 12x24ft above ground pool installed this year. The height is a bit of an issue as I have a marquee over it so I'm thinking of doing a half-dig of around 3-4ft to sit the pool in with a ft or so above ground.
I'm planning on a concrete pad. Question is do I need to reinforce the sides? The ground is flat/settled and has never been dug. Lots of tree roots in place stabilising the soil. Will the weight of the water hold the pool sides that are submerged, considering a ft will be above ground?
If not, what is the best way of doing this?
Thanks
Lafanga
Thanks
Lafanga
