My TA is high (120) and from what I understand on the Pool Calculator (and recommended levels link) it should be around 90. I am still low on chlorine levels (currently at a 1/2) and will be adding more tonight.
I don't quite understand this from the Pool Calculator: "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH. Note: Adding baking soda will also raise your pH"
Do I want to manipulate my pH levels on the Calculator to determine how much Borax to add or does this have to be the Muriatric Acid specifically???? I'm confused!!!
Yes, it can get confusing sometimes, but you are doing fine. Unless you are having issues with rising pH requiring frequent MA additions, there is no need to lower your TA.
My levels this afternoon:
FC: 1/2
Do not understand FC 1/2? Is this a typo?
pH: 7.8
IF your FC was below 10ppm when you tested your pH, use MA to lower your pH to 7.4 - 7.6 range.
TA: 120 (needs to be down to around 90)
See above comments.
Thanks!
