Ok, so I can’t see how this can make sense. My pool heater is only 2 years old, still under warrantee. This season each time I put the heater on it would ignite but then after 10 minutes or so the service heater light would go on, igniter off but unit frozen only way to turn off the unit was to cut the breaker.
Pool company comes out and they guy is telling me they had to replace a sensor that broke that has been going bad on a lot of the heaters they have been seeing. Then he tries to blame the fact that I run my vs pump at 2000 when I’m using the heater. He says it’s too low of a speed and what’s happening is the water is going into the system too slow to cool the coil causing it to burn up the sensor. He insists I need my vs pump set at 2900 in order for my heater to not get damaged.
The heater says the flow rate min is 30 /max 120 pm I think. What does that correspond to in terms of vs pump settings. The only issue I ever had with the flow not working was when I was testing the min. which was 1400 for it to go on. And even then it was a different light that went in it said service system instead of the service heater light.
I’m trying not to run my pump at 2900 to run my heater, but I also don’t want to kill my heater again. Does what he is saying make sense? The sensor was like a Y shaped metal wire piece. Is this an actual issue anyone has heard of with the pentair mastertemp 300? My model was made in 2020. Thanks for your help.
