Uh....sorry but no bueno. Strips don't give any accurate precision reading for chemistry. Yours are all over the place.
If your pH is truly that low, your TA would also be lower.
If your pH is truly that low you are doing permanent damage to your liner. And probably equipment also, as your pH may be much lower .... then again, might be higher since strips suck at giving accurate results.
Please do yourself a favor and read the links I sent, and obtain either the Taylor K-2006C or the TF-100 or Pro test kit.
The Taylor can be found at various sites online but
make sure it contains the FAS-DPD powder test for FC/CC .
The TF test kits can be found at
www.tftestkits.net
You have a good size pool. Until you get a test kit we can trust we're in a holding pattern.
You should stop using pucks as most likely they are complicating, if not outright causing, your problems.
Use Liquid Chlorine, most often 10-12% found in pool stores, Walmart pool section, HD and Lowes, etc.
I'd add one gallon a day and brush, until the test kit arrives.
Then we'll feel far more comfortable giving your good advice and not just grasping straws and guessing.
Maddie
