FC -5You may want to post test results to help people understand the water's chemistry. Other than LC have you added anything else recently? And it was pool chlorine and not bleach with possible additives?
I have nothing to add since the numbers seem fine but hopefully more knowledgeable people will come along!FC -5
PH- 7.5
CH- 450
TA- 90
CYA- 30 (I have an autocover so keep this lower than recommended)
Liquid pool chlorine only 10% strength.
Added anything else like calcium, phosphate remover, baking soda, etc?FC -5
PH- 7.5
CH- 450
TA- 90
Not since opening. Added calcium at the beginning of the year to get it back up to where it’s at now.Added anything else like calcium, phosphate remover, baking soda, etc?
This is the pool essentials from Walmart.I switched away from Chlorox Bleach (with additives) last year, and now I am using Pool Essentials Chlorinating Liquid, sold at Home Depot, Walmart, etc.. Now, I've had the same cloudiness issue lately, with similar test results.
What are you using for Chlorine?
I just picked up 3 gallons from Walmart, I bought it because people had a good experience with it. I'll have to keep an eye on it as I add it - do you have a date code on it? The ones I picked up was 2023 181 - so June 30th.now I am using Pool Essentials Chlorinating Liquid, sold at Home Depot, Walmart, etc.. Now, I've had the same cloudiness issue lately, with similar test results.
Usually seems like adding chlorine and getting a reaction is caused by metals in the water. But those seems to turn green or brown.Not since opening. Added calcium at the beginning of the year to get it back up to where it’s at now.
Yesterday I picked up 6 from Lowes, and the date code is 2023 182.I just picked up 3 gallons from Walmart, I bought it because people had a good experience with it. I'll have to keep an eye on it as I add it - do you have a date code on it? The ones I picked up was 2023 181 - so June 30th.
Any progress on your end? My tests have been inconclusive and probably don't apply to your pool.Water is crystal clear until i add liquid chlorine then it gets milky. Never had this issue before. Any tips?
