About not seeing bubbles from the main drain, not blowing it out completely, do we really need to worry about this?
Water freezes from the top down. Since the main drain is always open, therefore an escape for water, or an expansion path.
I am assuming that the pool water will not freeze all the way down to plug the main drain.
I called my pool builder and they said it is fine if I don't see bubbles, and to blow it for a few minutes and then close the buttom drain.
