- Jun 2, 2022
- 14
- Vinyl
- CircuPool RJ-45 Plus
Hi, this is my first season using a SWG. I currently running it at 10%, 8 hours. The nights are now getting cold, the heater running at 72 degrees( to keep SWG working) and the leaves are now falling. So I'm getting closing supplies together. I've closed my pool a few times before without help. My question is when it comes to increasing the chlorine level at closing do you shock the pool or increase the SWG to a higher percentage? If higher percentage how high? At 10% the total chlorine is between 3-5ppm.
Can you pressure wash a salt cell, or do you have to use mureic acid or both?
Can a salt cell be stored outside in the winter if the plumbing has been drained or kept in a shed or does it has to be kept indoors?
