Hi all, new to the board but wanted to say hello and ask a question of those on the board with familiarity with Polaris EOS Controllers. I started having issues a few months ago with the system randomly changing the date and time. Regardless of how many times I reset it, it would generally advance the date and time, screwing up my pool operating times (San Diego, Time of Use on Electricity so I run it after 12am). I had a feeling there was a small, (hopefully) replaceable watch-type battery that I would be able to replace for an easy fix. No such luck. I have attached photos of the Command Board, and I believe there is a battery but from my inspection of it, you cannot replace it based on how it is installed.
Anyone with any experience here? I bought the home in 2010 and I believe the pool was installed 4-5 years prior to that. It doesn't look like there are replacement Command Boards available online. If I need to replace the system, what would you recommend that will integrate with Jandy valve actuators? Thanks in advance for any help or advice here.
