Recently our 8050 has stopped running after about 1 minute. The cleaner is cleaned out; put into the pool and goes to the bottom as it should. I press the start/stop button to begin the cycle. It runs about a minute before turning off; the cleaner error indicator begins to flash once every second. Usually this means the cable isn't connected correctly, so I checked that. After so many attempts, I simply unplugged the entire unit from the wall and unplugged the cable over night. Today it turns on, but doesn't even run at all, it immediately shuts off and begins the one second flash.
Any suggestions as to what the issue might be?
Thank you.
Thank you.
