Thanks 1poolman1
The main problem with each of the “mechanisms” is that the small gear is being stripped.
mechanical failure.
The wall screen is in place, and cleaned each time the collection bag is emptied.
As to the restrictor plates, they are not in use, and have not been since I acquired ownership of the property 10 years ago.
I am considering to attempt at removal of the backup valve entirely, to see the results, but I’m not sure how to plumb without the valve, as the hose attaches to the ends of the backup valve on either end.
Just as an added FYI….recently my main pump went bad after 20 years, so I saw an opportunity to get away from having to run two pumps simultaneously, so I talked myself into purchasing a Dolphin Robotic cleaner.
I ran it for 30 plus hours and achieved absolutely nothing.
I returned it for a full refund.
Also…..to anyone with a similar problem to mine, in regards to your backup valve.
You do not need to replace the valve, only the internal mechanism.
Thanks Sandy
