Polaris 360 hole
Margaret 73
19
Washington DC
One of my neighbors picked up the Polaris and broke off the tab. That’s in the front, not the tabs that hold the bag on but the tab in the front. It doesn’t seem to have affected it at all. It’s still running around picking up debris acting. Normally I’ll attach a picture. What should I do, leave it alone? 271A8BE2-C3EB-4E06-A590-D3855D4F52F9.jpeg
One of my neighbors picked up the Polaris and broke off the tab. That’s in the front, not the tabs that hold the bag on but the tab in the front. It doesn’t seem to have affected it at all. It’s still running around picking up debris acting. Normally I’ll attach a picture. What should I do, leave it alone? View attachment 519268
If you can get the piece, it can be glued in with Plast-Aid. If it doesn't cause an issue with debris bypassing the bag shouldn't be an issue. If it is causing a problem:
There shouldn’t be water streaming out of the front right? Seems like debris may bypass the net.
