Hi family-just making my first post on here after lurking on here forever and then joining a while ago as a guest. This forum is amazing! Hello to everyone from Houston, Tx. I have a two year old Polaris 280 in apparently good condition, tires, gears, pressure all good. Wheels move as they should and it propels itself into the pool if you take it out and put it on the deck. The problem I'm having is that when the backup valve which is the fourth one I've put in this thing in two years activates, the cleaner flies through the pool with great velocity. It seriously just flies around! I took the cover off one time and found the tube dislodged that transfers the pressure from the hose to the two jets and zip-tied the hose on for secure fitment. I also took off my non-OEM non-genuine backup valve I've been buying on Amazon for 1/3rd the price and put on a brand new Zodiac/Polaris OEM backup valve and that didn't help. When it cleans forward it does fine. Doesn't climb stairs though, just goes up the sides of them and then comes down. It does climb the wall. Pressure coming out of the rear tube and tail is strong. When it's on the ground all the wheels are rolling. There's little or no pressure release from the main valve at the wall, as I learned recently that this should be tight and not allowing any release. It's almost as if the setting for pressure on the backup valve is too high? It has the same behavior with the OEM and non-OEM valve. Nothing is clogged. I took apart the three screws inside where the inlets are for the jets and saw no obstruction. I should add that before changing the backup valve and noticing the tube was disconnected I had relatively trouble-free behavior from the cleaner for a while. I really don't want to buy a new 280 as these suckers are expensive but I can't figure out this two month long issue! Help! Thank you so much! Below is a picture of it right before it hits the wall, curves around then the backup valve takes it on a magic surfing ride through the pool. Fun stuff!
