- Sep 17, 2022
- 65
- Plaster
- Hayward Aqua Rite (T-9)
I have replaced the capacitor as I had one as backup so it’s not the reason. When I turn on the cleaner the shaft rotates a bit and gets stuck. Removed the shaft cap and used a wrench to rotate to clear the clog but the shaft is super tight. I’m able to turn only 180 or max 270 degrees. What would cause such a tight clog? What’s my best next step to try before calling in a professional?
