- Oct 7, 2021
- 36
- Fiberglass
- Pentair Intellichlor IC-40
Hello, I have the Pentair SuperFlo VS and my PB installed 2” plumbing on both return and suction sides. However, he reduced the pipe down to 1.5” for the last 2 feet. Would this cause restriction of water flow? I ask because when I use the vacuum port he installed and turn my pump to “clean” mode (about 3200 to 3400 RPM) I seem to experience cavitation and the pump looks like it’s not getting enough water to run properly. So, my workaround has been to keep the skimmer slightly open but this makes it more difficult to vacuum. Would replacing the 2 ft of reduced PVC make a difference? I’ve also checked everything around pump for air leaks and there do not seem to be any.
