Plumbing Help new pool owner
Ez809
13
New jersey
Hey everyone im a new pool owner and this is the plumbing from the previous owner its having some leaks around the pump fittings and the pump starts running dry after 10 min could it be because of the leak and does the plumbing look appropriate thanks
Look closely at all of those areas BEFORE the pump. That's your suction side and it's probably pulling in air form somewhere. Those rubber coupler & clamp areas are suspicious. It also looks like someone applied a bunch of silicone goop at the pump adapter. But you look like you have a few places where air could be sucked "in". Just take each one at a time slowly to ensure they are air tight.
