so if I went with the 7/16 nozzle fitting (212-3470) fitting which is at a 17-20 GPM, would that be a better choice? I am not necessarily putting them on the face of the steps. I am fir sure going to put two on the pool walls by the steps, shooting across the steps from one side to the other. So I can choose the depth and location. IF I put more than two, I was thinking of putting two more of them on a step face (probably the second or third step).
And I guess I am asking in terms of my pump selection (Pentair Superflo 1.5 HP, VS 342001) and its flow rate to be able to suffice. As is indicated from the earlier parts of this post, I have 2 inch plumbing everywhere, 4 regular returns, two skimmers and two main drains. My pump is not installed, so coud be swapped because I can return if needed and get the Intelliflo 3HP VS pump.
