- May 23, 2015
- 24,443
- Plaster
- Pentair Intellichlor IC-60
If you cover the spa with an opaque cover you will be able to manage the spa chemistry better and you won't need to run it as much. That being said, I do agree with ozdiver that a separate spa will cost you more in "maintenance". You basically have two swimming pools sharing the same pumping system.
Let me ask you this thought experiment - if you completely scrapped the in-ground spa idea, how much money would you save and could you purchase a stand-alone hot tub that would be easier to manage?
If you stick with the spa, you might want to consider a supplemental UV/Ozone disinfection system.
