I have this same issue as every time the water moves, it flows out of the skimmer overflow hole. Ugh! I have since had my husband insert this little plug and it definitely make a difference. Snug and done. Has anyone tried these plugs? Thoughts?
Welcome to TFP! When needed, owners often use pool winterizing plugs for various reasons. Curious, it looks like your post was moved from someone else's thread. Why are you plugging-up your overflow tube? It might also help if you update your signature with all of your pool and equipment details.
Hi,
I'm letting anyone know that I think I've found a resolution for the skimmer hole plug. It's not flush but it's working. I will provide pics below. But it is saving having to put water in the pool so often as any movement creates loss from the overflow hole in skimmer. I found these at Ace hardware.
