I stuck a rubber plug in the return jet so as not to have to drain so much water on my above ground pool, but it isn't stopping the water. seems the jet piece after unscrewing the collar that holds the ball is pressed in to the fitting. I was thinking of either some type of static cling vinyl cover over the whole area or use an inflatable pipe plug in the hole. Any suggestions?
John
John
