- May 23, 2015
- 24,434
- Plaster
- Pentair Intellichlor IC-60
Also, not sure if you're married to the idea of having a blower on the spa but many of the expert builders here will say that, if the spa plumbing is done right, a blower is unnecessary. Could save you a small bit of money to do away with it (and they are noisy!)
Also, have you considered running the waterfall using an entirely separate pump?
I only ask because water features like waterfalls are low head / high flow features. Unlike bubblers and returns, waterfalls and scuppers work best when the pressure is low but the flow rates are high. And open pipe water feature like that on a high head pool pump can cause the return side head loss to be so low that you can actually cause the pump to cavitate. I know because my pool was designed and built with a 3HP WhisperFlo pump to drive a waterfall and it is total overkill. I had to add a shutoff valve to restrict the flow and increase the back pressure on the pump return or else it sounds like a giant bag of marbles rattling around inside the wet end. Pentair makes waterfall pumps specifically designed to move lots of water at low pressure.
