Fantastic! When it does, refer back to post #2 at the top. We need to know just 4 things for now:. pH, CYA, FC and CC. Everything else can wait until after we get the water clear.
Don't worry, this is really pretty simple. The bottom line is that we have to bring your FC to 40% of whatever your CYA measures at until the water is clear. This is easiest if your CYA is 30 (optimal) - 50. It can be done with CYA up to 80, but over that it takes a lot of chlorine. So if CYA is higher than 80, it's easier to lower it by draining and refilling some of your water.
All the other stuff pool like pump run time, time of day to add chlorine, etc., is mostly just personal preference. Once we start slamming, which is the process of bringing your FC to 40%, you'll want to run the pump 24 x 7 to filter out the dead algae. And as I stated before, the more frequently you can test and add chlorine throughout the day, the faster this will go.
That's all you need to be concerned with for now.
