Hello Everyone,
I live in northern Virginia and am looking at pulling the trigger on an AGP. I was hoping to get some help with suggestions on setup. I talked to the guys at the pool factory website to order a pool but didn’t get much on specifics. I know at the end of the day there is a “better“ choice out of the options they provide (because the great information provided in the introductory section of the forum) when it comes to the pump, filter, liner choice, etc. Need some direction on choosing components for a 15x30.
Pools considering:
Is it worth the extra money to get the aurora?… as it appears to be all resin. Do these pools really last decades if well kept?
We are building a deck around most of the pool, a little gazebo area on one side, a little bar top area on the other. I would say the area gets good sunlight from about 12 to 7 in the summer.
Considering solar to boost the heat / use in conjunction with a solar cover.
Thanks for any help or simply a point in the right direction. Tried to skim over the site a bit over the past week… so much to learn!
Pools considering:
15'x30'x52" Saltwater 5000 Oval Above Ground Pool
Leading edge pool that struts its stuff with such utter elegance. Saltwater 5000 Oval Pool developed advanced techniques that will eliminate pool corrosion.
www.thepoolfactory.com
15'x30'x54
Transform your outdoor space into a haven of relaxation with a premium pool like the 15'x30'x54 Saltwater Aurora Oval Pool. Our pools provide hassle-free enjoyment!
